1 - 2 of 2 Posts
I have a 2003 9-3. The headlight alignment is awful. I tried adjusting them with a allenwrench. Unfortunately there is enough travel in the adjustment screw. It seems like the driver's side low beam is pointed to low, while the passanger's side low beam is aime to far right. I replaced the factory bulbs with Sylvania Silverstars which has help some, but when it is raining out at night its hard to see. Any suggestions would be welcome. Thanks
Turn on your high beans are they aligned? If they are then your bulbs are not seated correctly, I had my headlights replaced a week ago (by a Saab dealership) and they put one in mis-aligned and I went through the whole adjustment twice before I asked on this forum and was told about the seating issue. Pull them out and make sure they are both seated correctly, it had my driverside low beam shooting at the ground and off to the left. . horrible, but an easy fix.
SG
1 - 2 of 2 Posts
