Hello All,
Recently my '01 9-3 SE decided to run poorly. After a sustained moment of spirited driving (triples <3), it seemed to misfire while running, so I tested the DIC and replaced the plugs. Both were fine, the plugs made it run a touch better. It still seems to run very roughly at idle, and settles down a bit at higher RPMs. I checked the exhaust, and there is fluid dripping and a tiny amount of oil droplets. The turbo has been replaced, so I know it isn't the seals etc. My thought is the head gasket went bad? The spark test I did with the DIC and new plugs confirm it isn't the ignition. There was the smell of gas, but that disappeared with the new plugs. If it is the head gasket, I'm sure the timing tensioner could also use an update. The car is stock, except for the ram air horn. Hopefully someone has some help, Thanks in advance
