Thanks for all the advice! I tackled the head removal today and all went pretty well. A few hoses need some attention the exhaust was leaking a bit at the head. I found out that a majority of the coolant passages were blocked at the head gasket
. The car had been sitting for 5 years when I bought it back in 2013, perhaps that is when all that blockage at the head gasket formed???? I can't tell if the head gasket is original or has been replaced at some point but, it was overdue for a new one.
The gasket was leaking into the cylinder but the block and head surfaces are were not corroded from what I can tell and I don't see any cracks.
I'm going to take the head to the machine shop and ask that the exhaust valves are lapped and not ground, is that correct? Also have the exhaust studs replaced. Any other advice?
Hopefully the head is straight and can be milled if necessary.
