Hi, I am the owner of a 1995 900s with 82000 miles on it. I think I have a loose wire in the dash board that makes the hazard lights flicker on and off, so I was wondering how you take it off, and if it’s reasonably easy, also where I would be able to get a good service manual.
Thanks
Will
Check the actual tail light grounds first. Why do you think it's under the dash?
Unless the ICE unit is failing...
But I would start with grounds and maybe the actual bulbs.
definatly grounds and in particular the ground to the switch. I don't think the bulbs would be messed up if you turn signals seem to work fine.
