1 - 11 of 11 Posts
2007 2.8 V6 Turbo Aero estate.
Random misfire at idle, was also missing under load but new set of NGK spark plugs gapped at 0.8mm seemed to have fixed this but still random misfire at idle.
Any help much appreciated???
Cheers.
@Mok T Do you know what plugs are fitted? If the answer is no,then start by changing them.. Should be NGK PFR6T or D-10G..
If the correct plugs are fitted,just drive it till code/s is/are triggered,it can expensive just throwing parts at it..
1 - 11 of 11 Posts
