I have 9-5 wheel on my 9-3 for winter.
However, that's not that model but it fit perfectly except that I had to use spacers on the front wheel unless these spacers the wheels would have turned because of the Aero brake galipers. But those spacer costed like 5$.
Again, I don't know if you will need spacers but those wheels should fit perfectly.
Thanks
Those are the exact rims I put on my 93.
I initially bought some cheap spacers that made the offset exactly what stock 93 rims are, but subsequently went with a set of Eibach spacers that were probably twice as thick as needed.
It looks a bit nicer IMO, and the Eibachs are hubcentric and included the correct length bolts to make up for the spacers (just like the non-rusting bolts some people replace the stock ones with, only longer).
