Engine is hard to start when it's hot after long highway drive since three weeks ago.
Once it get started, idling is rough and barely stays on the idle unless I push gas pedal constantly. If I try to drive, engine wouldn’t take the load and dies out unless I gas up over 3,000 rpm at least. Once it passes its hipcup intial stage, engine runs perfectly normal.
Two weeks ago, I experienced similar situtation while driving.
I was struck in the heavy bumper-to-bumper traffic during the unseasonably hot weather for an hour. My Saab began to jerk in the gasping breath. I thought I was out of the gas for a moment but the gas tank was full. As I pressed the gas pedal all the way on the floor, it wouldn’t supply fuel but kept jerking as if the engine dies off any second. I had to repress gas pedal constantly. Once the traffic easied out in normal speed, driving was no problem.
Cold start is no problem. When the engine is cold, it starts right away.
No OBD error code shown.
Engine temperature is normal.
Recently done :
-Thermostat, water pump and hoses replaced last weekend.
-spark plugs, spark plug wiring, distributor, distributor cap. O2 bank1 sensor replaced. (It -began to happen before I replaced these parts.)
-Fuel pump was replaced on 9/5 by a local mechanic.
Any thoughts?
Recently done :
Any thoughts?
