1 - 9 of 9 Posts
I hope you will forgive my illiteracy, but I can't read 99's 9-5 oil dipstick after checking the oil level.
Contrary to 6 cylinders 9-5, where dipstick clearly indicates "Min" and "Max" level, 4 cylinders cars, like mine, simply have a dipstick without any visible indicators. Instead, it has a range area separated by two black rubbers. What's confusing is that the bigger piece of the rubber located at the very end of the dipstick.
I know it's ridiculously simple, but I can't figure out how to measure my oil level
Hi, the flat sqaure part is the level, so the bottom bulge is your minimum and the top bulge is your maximum, I believe the difference is 0.5 litres. So if your oil shows in the flat portion near the top its great ;)
One clever chappy painted one flat side with white paint (high temp paint) so he could read his more clearly ;)
When I check my oil level the oil on one flat side goes just above the bulge and on the opposite side its shows oil level just below the bulge? I just take the lower oil level reading which shows that oil level is fine:D
When I check the oil level, its mainly always just after a drive. I turn the car off and let it site for about 5mins and then check the it (as per the car manual says).
Hey there bobsaab - yes, you're right, I normally keep more oil in than is shown in the picture - I just dipped the very end of it in the oil for illustration.
Btw, IIRC, this little modification is as nothing compared to Chris' rather fancy dipstick cap!
Yours is rather more practical!
Imagine who would be daft enought to mount a "metal" badge that you have to grip hold of in a hot engine bay :eek:
White cotton ones to open the doors :cool:
Leather ones for driving ;)
And sexy latex ones under the bonnet :p
1 - 9 of 9 Posts
