Hi all, When my 90 900S is warmed up & running for awhile & then shut off for about 20 minutes it is hard to start. It will just turn over a long time & when it does start it smells like it has been flooded. Then when the engine is cold it will start right up. It will also start right up when it is started up right after shuting it off.
Thanks Bud
Jezzadee, Thanks for the reply on the NTC Sensor. Is that the one between the rad & the thermostat? I wasn't sure where it was located.
Thanks Bud :confused:
Thanks again for the pic. That makes it pretty clear where it is at. I'll see if I can find one & try it. I hope I don't have to go to the Saab dealer as they are not close to me. I'll let you know if it works.
Thanks Bud :p
