1 - 2 of 2 Posts
I have an 03 Vert. I have a problem with the Soft Top Latch Release Pull Handle...
the problem is this. Sometimes if you pull a little harder than normal the whole handle comes out in your hand. If you shove it back in really hard it is fine and if you pull again it operates as it should. Any ideas on how to fix this? It only does it sometimes...I don't get it. The dealer I bought this from can't get it right....
There is a TSB on the latch handle, but not sure if it is the same issue. There are two o-rings in the mechanism that Saab now wants you to remove.
1 - 2 of 2 Posts
