I though it was a motor mount but someone told me it could be a bearing how hard are these to change? does the whole rotor have to come off?has anyone delt with this problem?
Moderator
Try changing tyre pressures to see if the noise is affected. Bearings will rumble rather than growl. If the bearing needs replacement, it's mainly DIY but you will need a mechanic or engineering shop to press out / in the bearing itself. Bring them the stripped down hub and the new bearing.
yea it is more of a rumble.. hopefully i can get this problem fixed.
'thanks for the info
Search this forum for info on bearing replacement--there are a number of posts in these archives that you'll find very useful :)
