1 - 7 of 7 Posts
I'm chasing a power lock issue and in doing so checking all the grounds. G14 is suspect because I swapped the seats for heated/vented from a 2009 Aero.
Does anyone know where exactly G14 is? WIS says "On seat member under left-hand seat"
Font Parallel Rectangle Circle Pattern
but I don't see it.
Thanks!
Cleaning the ground didn't help, going to look at the TWICE unit itself. One clue is that when I use the key fob to lock and unlock, it actuates the front passenger door only. When it does this, there's a rythmic clicking sounds, like coming from the SID, sounds vaguely like the turn signal electronic clicking noise. Does this mean it's finding a fault or thinks a door is open? No faults come up on my Tech2. Thanks for any input.
The battery is almost new and has been on a trickle charger, I'm confident it's OK. Also cleaned and secured all of the grounds in the engine compartment.
1 - 7 of 7 Posts
