1 - 2 of 2 Posts
The clutch pedal on my C900 has gotten very hard to press. The clutch releases perfectly, it seems like the actual pedal box is metal on metal and it makes a grinding sound. So again, the master and slave are working fine, but mechanically there is something wrong. Are there some bushings on there? Is this a common failure?
Thanks,
Tom
only grinding/? would possibly come from your connection from your pedal to M/C and the clevis pin is nackered,, but sounds more like a threust bearing stickingon the shaft.
but hard to press could be a ruptured pipe(the rubber one) and a piece has dropped down and as you press it blocks the flow, but once released it will move out the way
try a bleed of the system to see if it alters anything, but remember to check the 'clutch' level inside the main reservior is topped up
1 - 2 of 2 Posts
