Last month my '91 turbo began grinding intermittently when I shifted into 5th. I knew I had a bad clutch master cylinder and replaced it. The car continues to grind when shifting into 5th, regardless of whether i double-clutch, unless I leave the clutch disengaged long enough for the engine speed to settle to idle, at which point I can select 5th with no problem. I do know that my clutch pilot bearing is on its way out, could that be causing my problem? Or is the synchronizer a more likely suspect? None of the other gears, including reverse, ever grind.
Seems like the clutch is not disengaging properly. What happens if you keep engine speed to what the speed would be in 5th gear, clutch disengaged?
If I depress the clutch, match revs, and immediately go for 5th, it grinds. However, if I double clutch and match revs with my foot off the clutch pedal, especially if I wait a couple seconds before matching revs, it goes in gear properly.
