Hey Bladey, just checked mine...the main central one is fine but the two outer ones do move a lot ( a couple of mm) and sort of stick out a little bit near the bottom inside edge.... looks ok though as doesn't worry me.... must be the PPC and the air blast causing itBladey said:well they ain't rattlin mate.. they just look like the have sorta 'poped' out the main grill
How much more speed do you reckon the reduced weight of a mesh grill is worth? :cheesy:Viscouse said:Mine too. Was never happy about the fit of those. They ain't coming out though.
All the more reason to put mesh int here to tighten it up. :cheesy:
I've heard as much as half a second in 0-60... And almost a whole second in the quarter mile!Rob in Atlanta said:How much more speed do you reckon the reduced weight of a mesh grill is worth? :cheesy:
You guys are way off base here. The extra power comes from putting the manufacturers sticker for the grill on the rear quarter panel. The grill itself is just for show. Now I just need to find a NUSPEED grill. :cheesy:Viscouse said:And it'll straighten out the airflow as it enters the radiator. That's got to be good for another couple hp!
