· Registered
well, after much searching..I have found nothing on my issue at hand.
I have a squeak that i cant seem to figure out the source.
it happens when i am sitting in traffic, and rolling along at a constant speed, clutch in or out. and its not constant, its like a squeak. break. squeak, but its timed in sequence. as soon as i get on the brakes, or touch the gas, it goes away.
I am dumbfounded.
could it be breaks? wheel bearing? ive got no idea, so any help would be greatly appreciated.
Thanks,
.:Nick
· Registered
How are the brake pads? If they are fairly worn they may stick slightly in the caliper until you brake or give it some gas perhaps? :confused:
· Registered
That's most likely your brake pads grazing your slightly warped rotors. Press the brake and it stops and it's over shadowed by the engine when you get on the gas.
