The first is high engine idle, second one I -think- is ECU related. I was looking at Saaboheme's posts in this thread and I found P1653 and P1654 in it, but not P1652. Does anyone have any input on what this means? I did just put in a JZW stage 3+ ECU. It worked fine (except I got the high idle) for one day and then I got the check engine light the next night. I am going to swap to the stock ECU and see what that does, but I seem to have injured my back so I'm going to have to wait a little bit on that.
Anybody else have this problem before? It seems that one other time (that I found by searching) a tuned ECU caused this problem but there seemed to be no solution.
Thanks for any input!
Discussion Starter · #2 ·
After a little more research, I've found the P1652 code is for T7? But I drive a T5 car...maybe if I swap my T7 DI for a T5 DI that will do something? This was never an issue before...
Also, I've found the P1652 code to be called a ROM fault (what does this stand for? Read-only memory?). I'm leaning more and more to this being the tune...
Forgot to mention, P1652 also brings up Powertrain Induced Chassis Pitch Output Circuit. What the heck is that?
solution?
Hi
I have a saab 9-3 T5 with that code too. I have a tuned ecu, also tried another with the same softw. and have the same code :(
Did you please find the solution for the problem?
