Anyone had the dash turn inducator glow faintly while the car on or off? When I flip on the turn signal it flashes brightly, but there is still some glow in the background. Any ideas?
Thanks in advanced.
My guess is that it is a poor connection on the fuse box.
From experience, all electrical problems on a 99 are caused by the fusebox :evil: and even rewiring the fusebox only cures 90% :evil:
you could also try checking out the flasher relay - under the passenger-side kick panel. could be dirty contacts, or quite possibly the relay is stuck. good luck finding a replacement with the right number of pins - Halfords lists the wrong one for the car...!
Hope that helps.
Bad earth on the front or rear lights, finding it's way back to earth via the indicators, hence the glow!
Disconnect each indicator lamp (4) until the glow dissapears, then you know where to look.
