i can't find my handbook to see either how to change my glovebox light or which fuse to look at. its really stuck in and the fuses look ok. i'm guessing it probably pops out really simply, but like the side flashers, where do i start?! can anyone help?
Take the glove box out and get a better look. I can't remember how the bulb is held in but taking the glovebox out is a 5 min job.
G
For the side repeaters, slide them towards the front of the car, then the rearmost edge can be pryed away from the bodywork and the unit will pop out.
the glove light should just pry out, i think if you feal the short edge there is a cut out to get a pry bar under the light then pop it out, sounds easy i know but whe you consider the tight area your working it it isnt easy at all :roll:
