1 - 20 of 25 Posts
I can't find the fuse for the glove box light in any of my fuse box diagrams. Does anyone know where the heck it is?
Thanks
Rogo
Thanks
Rogo
I have looked at the owner's manual, and as I thought, this is not called out as a separate fuse.
If this fuse were to be blown, many things would not function..
Maybe the Haynes manual will list this in more detail..
That would be tricky. I found out that the power antenae and climate control lights are on the same fuse the hard way...
that could be because ng900s cant kill drls by pulling that fuse, correct?
at least thats what someone with an ng said in the last light changing discussion
Discussion Starter #8
Fuse for Glovebox.
I've just returned home now. I appeciate the prompt feedback fellas :)
Little background on the problem. I was replacing the bulb and shorted out the circuit (used my leatherman to pry the bulb out,it was wedged in hard, and I was pissed) and it shorted. Soooo-I think tidewatersaab might have it knowing now that the DRLs won't be shutoff by blowing the fuse (from Clevesaab)-I'll be going out and checking #15 since my DRL's are still on I am hoping that it's 15! If not I don't know what it could be.
Thanks for reply everybody!
Rogo
If it did blow the fuse, and its the same one as #15, then you wouldn't have DRLs...
How the f does that work? You pulled #15 and the DRL's are still on? On a 9-3?
On the same subject, but slightly off is the little plastic fuse puller..
Is not Saab supposed to include one at the fuse panel ???
Use something similar to a wood clothes-pin to pull the old bulb - if it fits..
Use a 5 watt festoon bulb for the glove box light ; a ten watt may fit but may cause problems (too much heat)..
Mine is also a no-light, thus I will finally look at it..
actually the NG900 is theone with unkillable DRLs the 9-3's are shut off by pulling fuse 15, at least mine, and most other 9-3s are.
Are you sure you healight switch is "off" rogo? :cheesy: This is very odd...
Discussion Starter #19
Okay! I fubared it-was dark when I checked last night and I was off by one fuse-15 killed the DRLs as you all said - but it wasn't blown-it was one of the 30amp fuses and now I can't find the damn thing! ARG
Rogo
Discussion Starter #20
I've lost the light in the hatch area now too.
Could it be one of the maxi fuses???
Rogo
1 - 20 of 25 Posts
