1 - 2 of 2 Posts
Odd problem. Periodically while driving all the display, spedo and tach (and the AC + Radio) will die. Vehicle still drives fine. When this happens the red light indicating the security system is armed ALSO blinks erratically. Generally, I pull the #4 fuse and this resets the problem for a while. Suggestions on a more permanent fix? Should I also pull the negative battery cable? Help!
David
1 - 2 of 2 Posts
