1 - 20 of 29 Posts
I've a '99 9-3 SE. I've noticed the boost never gets more than 1/2 way (straight up and down). I'm wondering if this is factory default and if I can get more boost without tuning the ECU?
If you have lpt, that is right.
Best (and safest) way is tune ECU.
I probably do. I do have a red ignition cassette but I'm not sure how that relates to which turbo I have
Red DIC is correct for Trionic5. All T5 use red DIC.
On the '99 base cars they had the garret t17 the high output SE had the T25, I would think the gauge would work the same whether you had either turbo,?
IIRC there is a tiny difference - a needle's width or two - between base and HOT. But straight up and down is base boost.
I find it odd that Saab would have on their dial, non critical boost range that the car couldn't achieve
I had the same year 9-5 and the needle would stop exactly between the white a red
Nonetheless they did on LPT models. But that isn't yours, since they weren't sold in the US. You are stuck in base boost.
Discussion Starter · #11 ·
Unless I get an ECU upgrade...
I think you should fix the problem that's causing base boost first. Is the check engine light on? Have you checked for codes?
Yeah, you will still be stuck in base boost with an upgrade. Base boost means a basic aspect of boost control isn't working. Set the ceiling higher won't change the defect.
Current: 2000 9-3 Aero 5d, Family: 85 900i 3dr.
I suggest you check the condition of your vacuum hoses, and any PCV check valves to be safe.
Remember boost is limited in 1st and 2nd gear.
I assume your SE is a manual - and not an auto?
Discussion Starter · #15 ·
Auto. My preference was foe a manual but they are hard to come by in Texss
This answers the HOT or not question...all 1999/T5 HOTs are 5-speed. The other easy ID is the intercooler...the 1999 HOT has the cross-flow, all others have the counter-flow. This is 1999/T5 specific.
I chased a low boost issue on my 1999...it can be frustrating, so you must be methodical. WIS has some procedures for checking base boost and full boost. I suggest buying a cheap bluetooth OBDII reader and the Torque app (Android...don't know what the apple equivalent is)...that will give you actual numbers (as reported by the ECU).
Start with vacuum hoses. A shop with a smoke machine can do a quick smoke check (this can reveal holes in the intercooler, loose clamps, etc.). There are ways to test the boost controller. Etc. When I get home I can dig out some of my notes, but these tests are pretty well known and should be thoroughly covered in this forum.
In the US at least, all 1999 9-3s had the T25. The difference between the HOT and not-HOT was software and the intercooler.
Not actually true, on a base model 9-3 it came with the T17 turbo.
1 - 20 of 29 Posts
