My Shifter went sloppy like linkage failure in my 95 900se turbo manuel but then stuck in nuetral. I removed the linkage but the gear select rob on the manuel trans is stuck all the way out and wont move. I dont think this car has ever had oil put in the trans and the sequences would scrap in 3rd on 4rth for as long as i can remember. So how screwed am I?
Find out what broke, then go from there. If the trans itself was grinding, sounds like it's time to put a new one in or get it rebuilt.
Are you saying the shifter itself is stuck with the linkage disconnected? Might just be jammed against the 5th gear stop, or the stop broke, etc. Lift the shifter boot up and inspect.
The gear select rod coming out of the Manuel transmission is stuck all the way out in neutral. I'm thinking of having the clutch held in while I tap it with a hammer to see if it will break free. I cannot find any images of how the the rod works, only the inner gearing of the trans itself.
