· Registered
Having recently installed Stage 1 PPC, I find myself agreeing with others' observations. It seems the boost gauge only goes into the red above 1st gear. This implies that there is a switch somewhere which tells the ECM or BCM that the trannie is in first gear.
Now you clever boys already know what I'm thinkin', dontcha?;)
Bypass that switch and you can really shred some tires in 1st gear:eek:
· Registered
No go on this idea.
It seems older Saabs limited boost based on vehicle speed vs. engine rpms. I'm guessing that hasn't changed.
No gear position indicator.
http://www.saabcentral.com/forums/showthread.php?t=36852&highlight=gear+switch
My research also indicates the reverse light switch is probably on the transmission case. The shifter may have a separate switch which signals when the car is in neutral. Not even sure if that's required to start our cars, as I always start in neutral by habit.
· Registered
The reverse light is on the transmission case, correct. Can't get the WIS to pinpoint it.
I haven't read anything in Turbo Control, Throttle Control, Torque Control, or anything control that suggests the gearbox is even considered when delivering power. Maybe it's covered in the TCS/ESP section, but I doubt it. I didn't see any line items for replacing any selected gear sensor.
