The past two times at fill up. I refuel the car get back in. The car won't start. It acts as if its flooded. The starter turns over but no fire. After 3 minutes it will start. When it does start it won't allow any gas pedal action or it stalls. After rough idling for a minute or so its ready to go. Then it starts fine everytime afterwards. Only happens at fuel up. SUP help please.
How full?
One question: are you "topping up" after the pump shuts off? If you do it mor than once you could be overfilling which will produce the problem you describe.
Generally after the pump shuts itself off, I allow one more cycle, then quit.
