Are there any fueling system guru's out there? I just went out to wash my car and found that my 94 vert wouldnt start...Its my daily driver and ran fine without issues yesterday.
I have determined the fuel pump isnt turning on. I unbolted the banjo fitting on the fuel rail and there wasnt any pressure or fuel leaking when the key is in the on position, or cranking over.
Per the bentley I put a jumper wire between fuses #27 and #30 and still no fuel pump noise/pressure.
I also located the fuel pump relays but the bentley is a bit vague as to how to test it.
anyone know what the next step is?
The car has red series injectors/eprom/apc. I was wondering if the increased fueling needs from these could have faulted the pump?
Thanks in advance!
-Jeff
Thanks in advance!
-Jeff
