Hi, Hope someone can help - A couple of days ago the fuel warning light on my 900 T16 came on while the tank was almost full and has stayed on since. I've taken it right down to empty and filled it right back up, but the light is still on no matter how much or how little fuel is in. Any ideas on what it might be?
I doubt that would be the case if the fule gauge still works, probably just an electrical issue. Check and clean all the grounding points and see how that goes.
Checked the Bentley manual and apparently the fuel guage and warning light both share the same grounding point - 9. The grounding looks fine and the guage itself works fine, it's just the light won't switch off. I put a dose of STP injector cleaner in the tank before the problem started - any chance that could have affected it?
