1 - 11 of 11 Posts
What do you guys suggest???
I have used sea foam and gunk motor flush. They have always served me well in the past. As for fuel system cleaner I have always gone with Lucas.
Same things I have used, just make sure to change the oil after you use seafoam ;ol;
You can use the Seafoam in the fuel system too; i've also used the Gunk.
That's what I'm after. I'm a fan of a flush at every oil change. My bigblock needed it done every change due to bad rings so I figure if it kept things clean in there it should work to fight sludge in the Saab.
Gunk engine flush says on the bottle "not to be used with turbo vehicles"? Anyone used the German Moto engine flush on a SAAB?
For Turbo Charged gasoline and diesel engines, use the Gunk Synthetic Motor Flush. Sometimes I go ole skool and add a qt of ATF right before an oil change; I always get feedback on this (atf); but it works for me. Some folks don't like using flushes (because it might clean the engine to well and create leaks); don't know what to say about that; I don't think that way.​
This one has intrigued me for the simple reason I've read decent reviews at removing varnish.
http://www.auto-rx.com/cart/order.shtml
I read a lot of great things about Auto-RX too, so I ordered two bottles that are still sitting in my garage. Mainly for the fact that I don't want to use until I have time to drop the pan right afterwards. One would think that anything flushed out of the engine will collect at the pick-up screen, so the screen should be cleaned after a flush.
1 - 11 of 11 Posts
