I have a thought and I am soliciting thoughts on this. My 05 Linear has a fuel sending unit issue. However the behavior of the unit is extremely consistent, so I have a theory. Its too cold right now in Ohio for me to drop the tank and see whats going on but I will be doing that as soon as weather allows or I borrow my brother in law's heated shop
. Right now I am using my trip odometer as backup. here's the deal.
When I first fill the tank to full the gauge shows empty, fuel light on, DTE - - -.
After some driving, usually around 100 miles or so the gauge starts working, DTE shows what I believe to be an accurate number based upon the odometer and calculations when i refill. for example. when the gauge is indicating 1/2 tank I am at 240 miles on the odometer (I am consistently getting 480 miles to a tank).
After the point where the gauge beings to work it will work all the way to empty and again once refilled it goes to zero for the first 100 miles or so...
If I recall correctly there is an alignment notch on the fuel unit and the tank. You must align them to avoid the sending unit getting bound up inside the tank. This car had a sending unit replaced not too long ago, so I am thinking maybe the unit was installed not without the appropriate alignment.
thoughts?
thoughts?
