Fuel regulator, Well I think I might have found the problem on my 93 9000. When I unhooked the banjo fitting at the rail end nothing happen when I hot wired the pump, but when I unhooked the fuel at the regulator (with the little vacuum line) before the rail the pump pumped very strong. So I am thinking the regulator is bad and blocking the fuel delivery. Could one of the members let me know if they think I might have it figured out? In other words, if you loosen the nut at the end of the rail after the regulator some fuel should pump out when the pump is running, right? I cannot see why it would not. This has been a real battle, so if you might know something PLEASE comment. Thanks in advance.
Steve
Steve
