1 - 14 of 14 Posts
Damn it to hell... I've had no issues with this car and today on the way to work my gas light came on. 20 miles later I parked at work. Came out for lunch, was going to leave and get gas... Started the car and instantly it died!
Fuel pump is making no noise when I turn the key on.
Checked the relay and the fuse, both are good.
I found online where u can jump two terminals on the relay to see if the pump sounds.. it did nothing.
My guess is the pump took a ****?? Anything else u recommend I try before I buy a pump???
Pull the hose at the fuel filter and see if it flows.
If you have voltage to the pump and no flow, then the decision is easy.
I pushed the schrader valve down on the fuel rail (service port).
No pressure, no fuel. I have a few issue. Plus I can't hear the pump come on with the key.
mine was the same way brother, i pulled the pump and hard wired it and it worked! ..so i eventually ran a toggle switch to the pump myself..i guess thats lazy but, it was 5 bucks and fast and clean..my pump was not priming ..relays and fuses all checked out as well..also got a discount on insurance for it :)..hard to steal a car when you dont know how to start the fuel pump..
Where did you get one for that amount?
Lol!!!!
Hey if it was an FD I'd completely agree, but its not.
Btw I would love to see pics of your REX. I'm a long time lover and builder of the rotary!
1 - 14 of 14 Posts
