Does anyone know if there is a difference between the feed side check valve of the fuel pump, and the return line valve? Can i just use 2 feed side check valves? I sorta need to know soon, seeing as im trying to get my rebuilt fuel pump back in the car. Thanks guys.
Just keep it stock, keep the check valves clean and operative...I would make no changes here..
Well, the problem is theyre both broken, and im looking to pick up some replacements. :( I think i may just go up to the stealership and pick up one of each, but the problem is the return valve only is sold with the fuel line which goes with it, which i dont need. It bumps the price from around 10 dollars to 54 dollars. Just looking to save a buck
