Yesterday I filled fuel tank and noticed fuel smell in cabin. When I removed fuel pump cover there was gasoline on top of the pump (housing cap was full of it). I dried everything, started the car and noticed that fuel is filling where pump wires are attached… When I wiggle wires pump will switch on and off. Both wires are hard and brittle and white one is burned at spade connector. It broke when I tried to bend it… Few years ago there was birned wire inside pump assembly and I replaced it.
Is it normal that petrol comes out of wire opening?
What should I do/check with wires?
What could cause burned/brittle wire(s)?
