1 - 12 of 12 Posts
Looking for a fptg for 1995 V6. Many ads say 'not for Saab'. I'm guessing that is a fittings incompatibilty. But does that appy to the v6? If there is fittings incompatibility is that easily fixed?
a regular pressure gauge should work fine. There are no fittings. Just remove the vacuum hose from the FPR and stick the gauge in the hose. You should get a reading of about 19psi. I have a 94 900se 2.5 so it should be similar.
was just searching through old threads... how would i go about installing a fuel pressure gauge on my 97 900se that i can read under load in my cabin? has someone done this before that could give me like a guide?
if you have the gauge it hooks up to the hose that goes to the back of the pressure regulator. I do not recall what the psi number should be.
yea but i want to be able to drive the car and be able to read what my fuel pressure while driving, stopping, hard acceleration, etc...
The pressure regulator is located on the intake manifold not in the cabin. It looks like a small gold valve with a hose going in and coming out. Standing in front of the car it is on the left side. One screw and it can be removed very easily. I new one is about 85.00 US.
yes i know what you're refering too im trying to be able to have a gauge in my car so while im driving i can see how my cars fuel pressure is under a load... i.e. when im boosting 5 psi while driving i should be reading about 50 psi of fuel... and so on... im just wondering where i can hook up a gauge to be able to view it from inside my car
Correct me if I misunderstand.:cheesy:
What we seem to have here is a vacuum gauge, not fuel pressure.
If the FPR is removed, then an Euro pressure gage could be screwed in its place ??
Or am I of a 900 I4 mindset ??
I have read that the V6 does have a port for a pressure gage.
byastremski said:
i don't believe that the 900 I4 does have a port which is why im trying to figure out how to go about it?
As i said in the other thread (in mods and tuning), im using a t-connector. Mounted in fuel pressure hose, before the rail. I cant find a picture, so i drew one. I think you can figure out the part after the connector by your self ;)
There was a post for just that, but I tried to search for it and got a blank page for search results. I think the search got overwhelmed and gave up.Renew your post as a new thread and maybe you'll get lucky.
1 - 12 of 12 Posts
