1 - 11 of 11 Posts
I have an 07 2.0T SS and I did a fuel pressure test. An immediate test came to 35 PSI. What should normal PSI be at? I’m sure 35 is too low. Fuel filter? Pump? I already replaced the regulator.
Normal from WIS is 3 bar ±0.1 bar so 43.5 psi ±1.5 psi. Note that reading will also be ± any gauge inaccuracy. Fuel filter is built into pump assembly.
You are on the slightly low side of spec? Any drivability issues? If not, I wouldn’t worry about it
How you checked pressure?
Engine stop, ignition ON? Engine idling? Full revs?
Yeah. I think I also have the valve issue. Idle and starting are rough. Between like 2000-1300 RPM or so when I’m slowing down only in 3rd gear the car slight changes idle and shakes.
Change fuel pressure valve first. It is cheap and easy to change.
Cold starting*
I have valve issue and car shakes in cold start. Shaking reduces after 30 sec - 1 min in idle and/or when you start to drive. It disappears when engine warms even a little. In my case no more shaking after 1 km drive.
No issues when slowing down.
Discussion Starter · #11 ·
The fuel pressure regulator? I already did. Or you mean the sensor?
1 - 11 of 11 Posts
