Don't know if the '92 fuel pump is the same as '94 and later, or if they have similar fuel level arrangement. There is a float linked by a hard wire which brushes against a flat conducting part on the fuel pump. Level is determined by electrical resistance as the float moves up and down. My guess is the float is stuck. Why does it happen all of a sudden I don't know.
This is inside the fuel tank so you need to open the flange on the tank in the trunk area, pull out the fuel supply and return connections, lift the pump out and look.
Meanwhile, just use the trip meter to gage the gas level in your tank. Matter of fact, I have been doing that on my '94cs turbo. Too lazy to open the tank up.
