Hey Guys i want to change my fuel filter but not sure exactly where it is located, also is this hard to do for a diy'er? Thanks for the advice!!!
The filter is located in front of the passenger side rear wheel.
It is an easy DIY. You can do it if you change engine oil by yourself.
Just one screw and two bolts.
This is very helpful
Also, make sure you order new banjo bolt gaskets with the filter...two large and two small. It's about a 5-10 minute job to replace the filter....
Thanks for the info guys i just changed the filter today outside my work with the use of a few of the mechanics tools, it was actually pretty easy and seemed to have smoothed out my idle so i am pretty pumped! Thanks again!!!
