I was gonna replace the Fuel filter... i have been preparing for this... u know spraying WD-40 the last couple of days and all that, and when it came to removing the bigger nut on the filter, it just wouldnt budge. Its like it siezed.
(B/w when i was reading about this many ppl had talked about running the car after removing the fuel pump fuse.. and that it would run for about 15 mins... this didnt happen with my car.. that car just shutdown the second i removed the fuse)
... so it tried to force it.. and force it more... until my spanner slipped and made a dent on the fuel line, that goes up from the bigger end of the filter. (From the looks of it, its fule line going up to the pump.)
So I put it all back and started the car... sure enough its leaking from that end.
I found this part online...
900 94-98 Fuel Line from pump to fuel filter ( http://www.thesaabsite.com/900new/ng900fuel.htm )
I really wasnt able to see where the other end of the line was going... and it looked like that end was not going to be easily accessible.. but just wanted to check with you guys.. if this is something a beginner DYI guy can do.
Here is something else i tried to do this weekend.. but i think i'm gonna have to give up on that.. i'm not comfortable removing the engine mount
http://www.saabcentral.com/forums/showthread.php?t=112035
Thanks for your time.
