The return check valve had broken while I was replacing the fuel pump. I ended up buying the feed valve thinking they were the same (and the return doesn't seem to be in-stock anywhere). Looking at the feed valve, would there be any issue with just cutting the tip off the feed valve and removing the ball/check valve portion?
Here's the two to compare:
https://www.eeuroparts.com/Parts/40617/Fuel-Pump-Check-Valve-Feed-21341766/
https://www.eeuroparts.com/Parts/48706/Fuel-Pump-Check-Valve-Return-21341767/
The original return seems to have a smaller opening compared to the pro-parts return. But not as small as the feed.
Somebody mentioned not needing the check-valve for the return line. But would opening it up completely make it too large?
