Your joking rightuberfast said:It helps to take the screen out of the dash before you remove the speakers. As far as routing wires, fish tape and zip ties offer proper cable management
Alan i will make you a pair of silk prototype tweeters that i dont comercially sell:nono; there just to costly and time consuming to make.alan forsyth said:i'm all ears to you'r suggestions shah![]()
i need a set to go with the old tweeters
if you can do that mate
Could you show some images how you set them to the doors? i've been pondering this for ages.ShadowWorks said:...
Making speakers is easy for me as i have 20 years of experiance, the hard part is making a housing for the Saab doors, takes ages![]()
alternatively, you can use a torx bit from one of those multi ended screwdrivers in a small socket on a ratchet! (i think they are 6.5mm or something like that)Matthew said:L-shaped Torx tools help when removing that dashboard grille.
Its just a little wood work, You take the door panels off and measure and mould a small panle to the same shape as the door cars pocket and ones its almost a perfect fit, you can trim it in leather or cloth and then screw and glue it from behind the car, the screws are only for holding it while the glue sets, i recommend a spary foam, remember less is more, the back of the panel should be drilled to provide a key for the foam , this will increase the weight of the door so make sure the speaker is as close to the hinges as possible.Nattefrost said:Could you show some images how you set them to the doors? i've been pondering this for ages.
Also: how do you exactly remove the front speakers? I removed all screws i could find in the dashboard, still the b*a*tard wouldn't move.
I'm going to buy caliber cce-4 to replace the old ones. Also setting some 6 X 9 to the rear.Do you want to replace your speakers or just pull them out?
