Apparently those switches are of the close-to-alarm type. So the opposite would be true (i.e. disconnecting the harness from the switch will yield a false closed signal to the pictogram). See the bold type below:
DESCRIPTION OF OPERATION
The part of pictogram 213 that covers door indication alerts the driver if any of the doors is not properly closed.
When the ignition switch is in the Drive position, positive current is supplied to terminal 5 of the pictogram and via lamps f, g, d, e and j for each door to the door switch in question.
If any door is not completely closed, corresponding door switch 208 will be closed, connecting the circuit for the associated lamp to ground and thus causing it to light up.
If the tailgate is not completely closed, luggage compartment switch 56 will be closed and lamp j will light up.
FAULT DIAGNOSIS HINTS
Door indication is activated by turning the ignition switch to the Drive position.
- Check that current is supplied to terminal 5 of pictogram 213.
- Check that the door switches are in proper working order.
- Check that the luggage compartment lighting switch is in proper working order.
- Check the connectors, wiring harness and ground connections.
Schematic (the 208's are the door ajar switches):
