1 - 7 of 7 Posts
Has anyone got any good advice about replacing the front headlight bulb on the passenger side (2004 UK model) - there is a rubber boot to remove -ok with that - but access to change the bulb is very limited because of the washer reservoir filler -
Do I need to remove anything else to get better access or is it a case of struggling?
Thanks
The washer neck just pulls up and out! then its rediculously easy after that :cool:
I agree removing the washer spout helps a lot, though I don't find it getting the cover back on 'ridiculously' easy. :D
One other trick, if you need it. On the front of the battery box is some kind of electrical control/relay type box, maybe the size of two cigarette packs. This unsnaps, and can be gently moved aside. It's the only way I can get the rubber seal back on without blowing a blood vessel.
Bulb light
Wow...is that so easy. I did change my left low beam over the lat week-end. It's very difficult...near heart attack LOL unless reading your post.
Thanks for the good tips
1 - 7 of 7 Posts
