Could use some pointers to a few steps as we're in a massive hurry and looking to avoid errors.
1. Front - How can I hold the crankshaft and remove the bolt with the engine out, tranny off? Is it too late? My mechanic said he could probably spin it off as-is with his 3/4" gun, but he's concerned about spinning the valve train backwards with that much force.
Should I just do this job later when the engine is back in? From what I see in the WIS, it looks like I can do this easily with the engine in... and if so, I will put it on hold until later. Time is short.
2. Rear - Tranny is off, flywheel is off.
a. From the WIS, it doesn't look like the plate that the starter mounts through has to come off. Looking at the engine, it looks like it might overlap the seal a little. Does it need to be removed?
b. Install instructions? The WIS suggests a SAAB specific "protective sleeve" and a couple drive tools. Obviously I have none of those. How do I properly install the rear seal without damaging it?
3. Flywheel Install
a. Flywheel Bolts are TTY, but bolts are not available in the USA. Does anyone replace these? Can I blue loctite them and just change the torque spec to something besides a TTY pull? I haven't seen anyone suggest replacing these when doing a clutch. I can't imagine that I'll be able to hunt down a proper TTY bolt from a hardware supplier.
b. What's the purpose of using (per the WIS) tool 8394868 as a "backstop" when installing the flywheel? How is it done in my garage?
3. Flywheel Install
