1 - 8 of 8 Posts
Stil ironing out my initial problems.
Drove abourt 200kms last night on freeway-car went beautifully.
This morning I have no clutch - just freeplay on the clutch pedal.
Discovered that the clutch oil shares a tank with the brake fluid and the small resevoir was empty with a small puddle underneath the clutch.
Any easy answers?
Thanks guys
This diagnosis is as good as it gets. The clutch master is gone. The clutch/brake fluid leaked through the seals of the master cylinder onto your carpet!
You can try to rebuild the clutch master for $10 before spending the $100+ on a new one.
I usually rebuild them once and then replace them at the next failure.
Spot on jefspg.
I was quoted $220 AUD for the part and 5 hours labour. Is that excessive?
Is it a straightforward job?
where can I get a new clutch pedal from in the uk and what should I expect to pay? also how long would it take to replace clutch pedal and rebuild the master cylinder?
there's a guide to master cylinder rebuild and clutch pedal replacement in the diy pages on this site http://www.twinsaabs.com/ looks simple enough to do i reckon...shall I go for it? bearing in mind i've never worked on a car....have built computers and lots of other stuff tho' so generally ok with tools..
1 - 8 of 8 Posts
