1 - 2 of 2 Posts
Thanks to murphwiz for the good installation instructions for the electronic throttle. So far so good. I've just about removed the old throttle body but I'm stuck on removing the electrical connectors - both the main connector and the limp home connector. Is there a release for these connectors or is it brut force. I've been using moderate force to separate the connectors without success. I haven't been able to find a release either. How are these connectors separated?? I though I might ask for help before I damaged something.
Thanks
John
Theres a release mechanisim.
Pull out the red (iirc) ribbed panel thingy :oops: this will automatically release the connector!
Might need a small flat blade screw driver to get it started!
To refit, offer the connector up, and then press relese tab, this will pull the connector home
1 - 2 of 2 Posts
