Ok so my friends 95 900se vert now has no working fog lights. The driver’s side was working. So he decided to get a new set of bulbs. Last night we changed them out. The driver’s side was done first and tested as still working. Then we did the passenger side. When I removed the cover I found that only one side of the spring clip was connected. I pulled the bulb out and it looked fine. Anyway we put the new build in and decided to test the lights. Except now neither of them light up. So I disconnected the passenger side one and tried again and still nothing. I checked the fuse and swapped out the relay under the hood and still nothing.
Before calling it a night I got out my probe light and poked around a little. I am getting no power to the fog lights in the front. However the fuse and relay both seem to be fine. Actually the relay seemed to have power to 2 of the 4 contacts no matter what position the switch was in.
The only other issue the car is having right now is that the driver’s side high beam doesn’t seem to work. Again I checked the fuses and relay. I think the problem is in the switch since it has some problems like not clicking so the high beams stay on. I doubt the 2 are related but I wanted to mention it just incase.
Anyway any suggestions about the fog lights would be appreciated. I am a bit baffled as to why neither of them works now.
