My foglights recently stopped working correctly. When I try to turn them on, they act temporarily, as if the switch doesn't "latch" to stay on.
I have swapped relays, still did not fix the problem.
Do you think the switch broke? That seems simple, but I think I might be trying too hard.
Switch is a push push so unlikely to be faulty. However, if it does go faulty then it may be triggering the relay under road vibrations.
They do not stay on while stationary or driving. I picked up another switch and relay when I was out. Going to swap out a sticky caliper for hopefully a good one, I'll see if I can remedy the fog lights.
