1 - 11 of 11 Posts
I spent yesterday afternoon re-routing the compressor side of the FMIC
had to get a flexible top rad hose like "John-w" has on his T8S
cos the top rad hose is in the way...
the new intake pipe came from a Volvo 940 turbo its the same as a 850 T5 item..
I've had to get rid of the headlamp wash/wiper & move the 2nd horn as these were in the way..
the intake pipe is a lot shorter & with a lot less restrictions in it :cool: it has got rid of the "lag" that I had before..
old intake pipe & top rad hose, the 9k rubber boot is missing from this picture as I'm using it on my new route
no horn & headlamp wash/wiper
some views of the intake pipe route..
notice the new flexy rad hose just laying there..
Paul
_______________________________________
Sleeper baby, no show & all GO.....................
Discussion Starter · #2 · (Edited)
some more shots of the route
now you can see the flexy rad hoes & intake pipes
views from below so you can see I can now lower the front of the T8 by -40mm without worrying about the intake pipes..
the throttle body side will be done later.
Paul
__________________________________________
Sleeper baby, no show & all GO..........................
The chin spoiler has been fixed now as well..
jobs for today fix the horn some where & remove other headlamp wash/wiper....
Paul
_______________________________________________
Sleeper baby, no show & all GO.................................
Matthew said:
What's the copper coil at the top right-hand corner of the radiator?
It looks like a windshield washer heater. It should be wrapped around a coolant hose.
Jon
jon1..
Banned
What are the dimensions of your intercooler? its looks like alot of clever work.
I was told the tow hooks had to be removed when piping an intercooler down there? how ist the IC secured?
How much of a HP increase has it been? do you think you will get better MPG?
compressor outlet
Have you rotated the compressor side of the turbo so that it ports downward rather than up? That would reduce a bit of length aswell would'nt it?
Discussion Starter · #10 ·
ShadowWorks & Si some info for you two :cheesy: :cheesy:
ShadowWorks, as for hp rise don't know, but I was only interested in a "cold" charge & mpg mine only does 15mpg :cool: :cool: hows the I/C fixed to the car.............cable ties ;)
Si, clocking the turbo no need if you use a volvo 940/850 intake pipe
as for Volvo I/C all the size's are here plus loads of other info & pictures
http://wwwrsphysse.anu.edu.au/%7Eamh110/Intercooler/volvo_intercooler.htm
HTH Paul
Sleeper baby, no show & all GO..................................
Discussion Starter · #11 ·
Matthew said:
Did you know you can unbolt and remove the battery tray?
Downpipe looking good :cheesy:
Matthew,
battery tray is now removed ;) & horn is fixed in a better place........
still to do fix the windscreen wash heater again..
Downpipe is good but................................... bl00dy hot as Saturady I burnt my forearms on it twice :cheesy: :cheesy: :cheesy: :cheesy:
Paul
1 - 11 of 11 Posts
