1 - 8 of 8 Posts
Well, its finally time to get it done. What else should be replaced while theyre changing the water pump? They have to remove a lot of belts as it is, so I figure the belts should be changed while theyre at it too, right?
Serpentine belt and ideler pulley change. At the same time check the alternator's charging to see if it's adequate as well as checking and replacing the radiator hoses, thermostat & heater core hoses if in need of replacing then do a radiator flush.
And don't forget to check the power steering pump's bearing and the AC's for noise or wobbling.
Parts 6 and 9 in this illustration on the left. the pulley 9 may have been eliminate o9n your car with the short belt already. this link also has all the instructions needed to repace the belt and pulley.
http://pages.infinit.net/mlbriand/saab/shortbelt/page1.html
http://www.geocities.com/ng900set/Serp_Belt/idler_pulleys.html
Buy a wazee pulley from wazee not any crappy pulley (made from alluminum intead of plastic and the bearing is replaceable). they hiked up their prices quite a bit lately though :x :nono;
http://wazeepulleys.com/saab/pulleys.htm
Since Wazzee has increased their prices, the availability may be better. But, has the bearing quality improved ??
But now, on an economic basis, I cannot buy it.
I'd just go the short belt route and renew the idler pulley and belt every 50K miles. But the under hood inspection ,every 3 to 5 K ,becomes very important as the idler pulley can fail anytime over 30K miles.. This can co-inside with the oil change.
There is no sense in doing a "blind oil change", in other words, inspecting nothing during this service time.
Canyon, what is this with a "lot of belts" ?
http://pages.infinit.net/mlbriand/index.shtml
Thanx to Mr Briand
Unfortunately the bearing is crap like you said but it's replaceable and costs like $2-$3 so it's not that bad. I just think they killed their market by hiking the price by about 40% :eek: :roll: :nono; :x
1 - 8 of 8 Posts
