the other day my tonneau motor started clicking looked through the forums and found what the problem was, also found a few tips on removing the motor assembly and not having to reprogramme top. armed with this information i started work removed motor and measured gap. it was out of spec i noticed then that the base plate for the motor was slightly bent.so i removed and straightened then refitted gap slightly smaller. i then noticed play between motor and manual release clip. had brain wave fabricated bracket to hold motor to gearbox drilled backplate and used hole allready present to hold bar over the top of the motor tightened bolts and measured gap now 35 mm refitted motor assembly crossed fingers and tried switch success roof up and down no noise from tonneau cover and one happy man
if i can help anyone else just contact me
dave 900se vert
